11-30-2019 05:09 PM - edited 11-30-2019 06:43 PM
When I'm trying to select any option in any menu, or select a picture, it's as though up, down, and left all work fine, but right (flash) is selecting as if it was the Func./Set button sometimes and Func./Set just acts as an arrow button, but they aren't just interchangeable. E.g., if I want to delete a picture, I can't because pushing left, right, or Func./set just toggles between Cancel and Erase. I can't select my phone when trying to connect with WiFi. If I am viewing pictures as an index, using either Func./Set only once or right only once will move to the right AND then select that picture.
I'm guessing this will need to be a repair. Just thought I'd reach out in case anyone has something I wouldn't think of. It is very disappointing as I've only had it for two weeks (bought new) and handle it very carefully. It has not been dropped. The buttons are perfectly clean. No residue or anything. No noticeable feeling or sound to indicate stickiness.
11-30-2019 09:33 PM
You're welcome, I am not aware of any other way to reset the camera. If I were you I would get on the Canon website, register your camera then give them a call or contact whoever you bought it from for and exchange.
11-30-2019 08:51 PM
Try resetting the camera to its defaults through the Menu, you may have inadvertently changed the Func Set buttons setting. In any case, your camera should still be under warranty if all else fails.
11-30-2019 09:05 PM - edited 11-30-2019 09:09 PM
Thanks for your response. Ok, so I can get to the screen where it says "Reset settings to default?" and the choices are Cancel and OK but I can't actually select OK with the Func./Set button. If I select OK and push Func./Set, it moves to Cancel as if I pushed left or right.
11-30-2019 09:33 PM
11-30-2019 09:35 PM
Yep. Thanks, anyway.
12-03-2019 11:12 AM
