how to reset mg5320
ruszub
1 REPLY 1
Michael
Hello ruszub.
If you are looking to reset the settings to factory defaults, please perform the following:
1.  Go to the Home menu or press the Home button on the printer.
2.  Use the up or down arrow keys until Setup appears, then press the softkey under Setup.
3.  Select Device Settings and press OK.
4.  Select Reset Setting and press OK.
5.  Select Reset All and press OK.
6.  Select Yes and press OK.
Once this has been done, the current settings will be cleared.
