Solution for error 1003 that did not work. Pulled plug. Drained power. 3rd try worked.
B10KayL
When the solution given by Canon Online Manual for Error 1003 did not succeed qwith multiple tries, I pulled the power cord, drained the power by holding down the on button for 15 secs. X 3 then replaced power cord and tried to print again.  3rd of these routines succeeded!
CSmith1
Thank you very much! Your idea worked. I've had this MG6820 for less than a year- I do print quite a bit but yikes! with a whole lot of ink bought, I was kind of freaking out that it would not work. I tried fixing the 1003, as you mentioned quite a few times to no avail but then followed your directionsSmiley Wink.
OT-----I have noticed just recently that the printer wasn't printing out the entire page from my web site-lines of type were missing. What could be happening? Any idea?
Thank you very much again.
4 REPLIES 4
CSmith1
Hi CSmith1,
So we can best assist you, we would need some more information to help narrow down this issue.
  1. Does this happen when printing documents that are not on a web page( word doc or text edit)?
  2. What version of Windows or Macintosh is installed on your computer?
  3. What web browser are you using?
SuMac
Unbelieveable!  Don't know how you figured this out, but it worked.  You saved my sanity and my printer.  Thank you.
canon error 1003 solution
Press the HOME button, select SetupDevice settings, and Print settings in this order, and then set Prevent paper double-feed to ON.
other
Press the HOME button, select SetupDevice settings, and then select cassette incorrect paper detection to No
this will solver error 1003
Enter for a chance to win!
April 20th-28th
