Slow first print with LBP6000
Jimtowner
I just set up a new LBP6000 on my iiMac running OSX Maverick. The first page printed takes 25 to 30 seconds. In the sales description on Amazon Canon repeatedly says first print takes 8 seconds or less. Is there a way that i can get the 25-30 seconds down to 8 seconds or less?
Patrice. thanks for your help. It turns out that your 3rd bullet was the culprit. I move to another port and it is working okay now.
2 REPLIES 2
Patrice
Whiz
Hi Jimtowner.
The estimated print time is with a document using a  standard 5% toner yield (about 16 lines at 12 pt font) on plain, letter paper.  Print speed may drop due to a number of factors, such as:
  • The length of the USB cable you are using
  • If there are any devices between the printer and the computer.  ( EX: USB hubs, switches, or extenders)  ***Note*** Canon recommends a direct connection between the printer and the computer.
  • Issues with USB ports on the computer
  • Paper size and type
  • Orientation of the document
  • The number of pages or copies of the document.
Please review these items and then print another document.  Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
