Reply
New Contributor
Accepted Solution
Selphy CP910 ink cartridge is jammed and cannot be removed
I have a Canon Selphy CP910.
The ink cartridge is jammed in the printer and cannot eject.
How do I remove the ink cartridge.
This is the second unit I have owned that this happened.  I replaced the unit with a new one, and it hapened again.
The removable cartridge will not eject.
Any ideas?
Re: Selphy CP910 ink cartridge is jammed and cannot be removed
Hello.
Please try the following to see if we can resolve your issue:
1. Turn the printer off.
2. Open the side of the printer to access the ink cartridge.
3. Push the cartridge into the printer to ensure that it is secure.
4. Turn the printer on and back off again.
Once this has been done, try to remove the ink cartridge from the unit.
If the issue persists, find more help at Contact Us.
New Contributor
After disassembling the unit, I realized the motor to the roller was still engaged and did not have a mechanical realease point.  The unit was reassembled and the ON-and-OFF-and-ON process released the roller, and the cassette popped out.  This is a problem I over thought.  Yes, the simple solution is usually the best solution (humility gained); my wife can't stop laughing!  Thanks for your help... seadog67
Frequent Contributor
Check this link on page 8. "Preparing the Ink Cassette"
Open the covers and try to stretch the ink sheet by turning the sprocket as shown in page 8 in the manual.
Happiness for your Printer
New Contributor
I tried to off and on the printer again, but it still stuck. Should i open up the printer and see if i can remove the ink?
New Contributor
Worked perfect, but I did have to cut the ink plastic sheet(reel) that was sticking out of the paper feed in The back. After turning off and on I just had to wiggle the ink out and all is good. I had the tools out to take this apart and. Soooo glad I checked and just pushed a button twice instead. Haha. Love my printer
powered by Lithium
