10-19-2014 05:54 PM
OSX Yosemite driver for Canon LBP3000 needed. When will one be available?
10-20-2014 07:53 AM
Also require a driver for LBP6000
10-22-2014 01:08 PM
Drivers needed for Canon UFRII as well. I don't think Canon has updated any of their drivers to work with OSX 10.10 yet.
This is something they should definitely be working to release ASAP now that 10.10 is released to the public as a free update. Especially since the developer beta's have been available since 10.10 was announced back in June... Kind of a slow roll out =/
10-22-2014 10:22 PM
Hi mvneufeld.
You have reached the forum for Canon USA. Since the i-Sensys LBP3000 is neither sold nor supported in the USA, we do not have the resources or references to provide the information you have requested. For information and troubleshooting assistance, please visit http://www.canon.com and look for the support site closest to you geographically.
10-22-2014 10:24 PM
Hi smukhi!
I will be glad to assist you. The driver is now available for the commercial release of the OS X 10.10 (Yosemite) driver. I recommend uninstalling the previous driver before installing the latest driver. To uninstall the driver, please follow the instructions below:
Location | Files and folders to delete |
/Library/Printers/Canon/ | CUPSCAPT |
/Library/LaunchAgents/ | jp.co.canon.CUPSCAPT.BG.plist |
/Library/Printers/PPDs/ Contents/Resources/ | Delete all the following files in the folders. CNMCxxxAUS.ppd.gz (xxx is a model name starting with [LBP].) |
When the [Authenticate] dialog box is displayed Enter the administrator's name and password, and then click [OK]. |
1. Click the [Printers & Scanners] icon in [System Preferences].
2. Click [+].
3. Click [Default], and then select the printer to be used from the printer list.
4. Select [Select Printer Software] from [Print Using].
5. Select the printer to be used from [Printer Software], and then click [OK].
6. Click [Add].
7. Make sure that the printer to be used is displayed, and then close the [Print & Scan] dialog box.
The printer registration is now completed.
I hope this information is helpful to you. Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
10-22-2014 10:30 PM
Hi danielkuhlwein.
I will be glad to assist you. So that I can better assist you, what is the model number of your printer?
I look forward to your reply. Should you need immediate assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
11-09-2014 11:59 PM - edited 11-10-2014 12:02 AM
Thank you very much Patrice,
I can now use my Canon LBP 3000 Laser Printer on OS X Yosemite Version 10.10
Regards TRISH
11-10-2014 01:59 PM
Thanks Patrice!
I believe the model number for our Canon is Canon iR ADV C5030 UFR II. From what I understand, printer drivers for this model that work with OSX 10.10 are not yet available.
11-10-2014 04:32 PM - edited 11-10-2014 04:40 PM
Danielkuhlwein,
I’ll check my model number on my Canon LBP3000 later today. The above driver definitely works on my Canon. When I phoned Canon I was told there is no driver available yet,that will work with OS X Yosemite 10.10 BUT THIS one above does work, for me, you just need to make sure you remove all the old files.
[CANON L11121E] Manufactured June 2006
11-13-2014 09:58 AM
Hi Patrice,
I recently updated OS to Yosemite as well and ran into similar problems to others here.
Thanks for your advice. I found it helpful up to the point where I had to locate my printer - LBP 3050. It is not available on the list provided. Only LBP 6000 and up are available. I tried installing those but it couldn't print, saying the printer was not compatible. I then tried the dropbox to change to 3050 model but I couldn't scroll down the list.
Any further advice on this point is more than welcome. Thanks very much again.
John
