Not detecting Canon MX340 after working fine for couple of months.
elmereraso
Hello
My pc is not detecting the Canon MX340 after working fine for couple of months.
3 REPLIES 3
kahveen
Enthusiast
Hi elmreraso,
As I understand, your PC is not able to detect your printer after long term usage.
Kindly advise the following below,
1)  Computer operating system
2) Any error message that occurred?
The following issue could be just a break off in communication with the printer and the PC.
Hope to hear from you,
Best Regards,
KahVeen
Hello
I am using Windows 7.
The message error said that Is not connection with the device
Thanks
Elmer
Hi elmereraso,
Thank you for your information.
You may want to try the following download to re-connect your printer to your PC.
Here's the steps for your reference,
1) Download and install the driver
2) Perform a print
a) Download the driver
- http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100461601EN.htm
b) Run the installation
c) Select "Wireless LAN Connection/ Network Lan Connection"
- if your printer is not detected, kindly select "Set up printer network connection via USB cable" and then press "Next"
* You will need to connect your USB cable for the following method.
d) Complete the installation
2) Perform a print
a) Try performing a print to determine the installation.
Hope it helps,
Best Regards,
KahVeen
