Reply
New Contributor
IP8750 Colour Reproduction Problem
Mac OS Sierra - IP8750 - Illustrator / InDesign - Macbook Pro 2011 / iMac 2014
First of all I've been getting some fantastic results from this printer, but also some very frustrating issues regarding colour reproduciton. I don't think there's a fundemental issue wiht the hardware, but my setup must be wrong somehow.
I primarily print illustrations using InDesign to layout my page before print. If I print Plain Paper (standard quality) colours match my screen and expectations well, as soon as I try to print Matte Photo (high quality) the output becomes MUCH darker, and magentas show a huge skew towards blue, with pinks becoming purple for example. My CMYK value here only has 4% cyan as well which is weird to me... All this is to Canon Matte Photo MP-101 (although the same is true on standard copy paper).
If colours were consistent between settings it wouldn't be so much of an issue, or even if I could print Plain Paper (High Quality) but this isn't a option as far as I can see.
My best guess as to why this is happening is that the "plain paper - standard" ICC profile does a fine job at converting RGB to print, but the higher quality profiles are expecting work produced under a different monitor calibration?! IDK but this is where my research has led me.
The best / closest I've been able to achieve is setting my display to Adobe RGB 1998 and reworking my illustrations to look right here, then output is a lot closer. It's just frustrating that colours are so good from the plain paper standard setting, but the output quality isn't good enough and the opposite is true for anything else.
Any help here would be appreciated as I'm tearing my hair out trying to get to the bottom of what's happening.
Thanks Smiley Happy
Highlighted
Re: IP8750 Colour Reproduction Problem
Hi wolfteam,
Does this issue still occur?  If so, it is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
powered by Lithium
