01-24-2013 08:10 AM
My printer was printing a document when I noticed there were only 2 pieces of paper left so I tried to add some more and must have done it at just the wrong time..now there are 15 pages of paper stuck and I can see them at both the input and output wrapped tight.. Can't pull even one page out the input..Is there any help or have I damaged the printer beyond repair?? Tried all the paper jam suggestions..but my jam is way, way beyond that!!
01-24-2013 10:39 AM
Solved!!! How? Take plyers and grab a bunch of paper(10 sheets ) from the input tray..pull really hard..I started from the bottom up and managed to pull out 30+ sheets..Lesson learned..Do not slam in more paper while printer is printing!!!
01-24-2013 10:39 AM
07-17-2017 03:57 PM
02-15-2018 12:13 PM
Key point.
UNPLUG THE PRINTER!
Once power is removed from the printer, the tensioner that's power-driven goes slack.
ALL of the massive paper jam pulls out almost EFFORTLESSLY.
04-22-2019 05:59 PM
Thanks for putting the solution there as I thought my printer might be done for. I did the same mistake, except with 25 or so pages. Pulling out the jam with plyers worked well however make sure you take it from the out slot.
04-19-2021 11:11 AM
What do I do . I can see the paper but it is too far in to pull out
04-19-2021 11:24 AM
Thank you. All the papers came out with one pull with my pliers
