06-17-2016 09:45 AM
I haven't used my Canon Pixma for CD printing for sometime and I have fogotten how to print a proof on paper first before committing a disc. Any hep please?
06-21-2016 02:30 PM
Depending upon the printer you're using, it should work nearly the same way for both printing on paper or a CD. The only major difference will be the media type, and where you insert it into your printer.
https://www.usa.canon.com/internet/portal/us/home/support?tab=manuals
Use the above link to download your printer's instruction manual. Hope this helps.
06-21-2016 02:30 PM
06-25-2016 04:25 AM
Many thanks. LOade4d paper into both top and bottm feeds. Worked perfectly. Thanks again'.
