06-08-2017 06:17 PM - edited 06-08-2017 06:35 PM
What's the difference? I changed the page size and trype directly on the printer to see but on the driver it didn't change. Are both required. I have a PIXMA MX 492 on Windows 10.
06-09-2017 01:50 AM
Hi MidnightNarwhal,
The printer driver allows to you select the paper size and type when printing from your computer, and selecting the settings directly on the printer allows you to select the paper size and type when photocopying and scanning directly from the printer. You will only need to select the paper size and type directly on the printer when making photocopies or scanning directly from the printer; otherwise, you will want to select the paper size and type in the application you are printing from on your computer, or in the printer driver.
Hope this helps!
06-08-2017 06:27 PM
Hi, MidnightNarwhal.
To have a better understanding of your issue, please let everyone know the printer model you are using, as well as the operating system (Windows Vista/7/8 or Mac OS 10.X).
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help via Email at http://Canon.us/SupportCF
If you are outside the USA, please click http://global.canon/en.html and select your country to find support in your part of the world.
Thanks!
06-08-2017 06:40 PM
Just curious. Printer still works. Updated OT.
06-09-2017 01:50 AM
Hi MidnightNarwhal,
Hope this helps!
06-09-2017 01:52 AM
Ah okok makes sense, so if I'm just looking at printing an envelope, just change it in the driver.
Cool thanks
