Can't print from pc to mx922 via usb cable.
mrmustard
I have a mx922 and I'm running windows 8.1
Can't print from the pc using a usb cable but the 922 will print wireless.
Is there a setting I'm missing?
Thank You.
1 REPLY 1
Ramona
Hi mrmustard,
There is not a specific setting to make it so that you can print via USB; what error or message do you receive when trying to print? Also, do you have another USB cable that you can use to connect the printer to your computer?
If this is a time-sensitive matter, additional support options are available at Contact Us.
