01-25-2018 12:35 PM
My new Pixma IP7220 "Garden" software has a CD/DVD printing feature.
It prints to the discs ok, but it leaves a small white border on the inside and outside.
I want to be able to increase the print size, so that the disc print is "borderless", with no white border, just like the Epson software allows.
Is it possible?
01-28-2018 09:32 PM
Not sure if the printer does borderless labels.. but this might help.
~CarePaks Are Worth It
01-28-2018 09:32 PM
02-02-2018 09:03 AM
Thanks, Rick
Yes, the "Image Garden" software does allow some adjustment to print diameters, but it does not allow the DVD to go fully borderless. I suppose that they don't want ink spilling over the edge.
I guess it is good enough, although Epson allowed for full borderless.
Thanks again!
02-04-2018 09:28 AM - edited 02-04-2018 09:29 AM
Glad it helped. Back in the day, I printed borderless lables on an Epson printer as well. I stil have my CD Stomper labeling kit. The printer has long since died and was never replaced.
Cheers
04-25-2018 02:03 PM
The My Image Garden software itself is likely the problem. I have an MX922 and have the same white ring around all my disc prints when using that program. With third party software, I can print the full disc face. Nero CoverDesigner and Disketch both are capable of doing so. Unfortunately, they probably won't print correctly with the default settings, and you will have to do some trial and error to get the print centered and sized properly. It can be a messy process. Not only can third party software print to the edge of the disc, it can keep going and print all over the tray. Once you get it set properly you can save the settings, clean your tray, and be good to go.
