just unboxed a new MF726 for home use and am finding I cannot email scanned docs without an error
montyseal
Each time I try to send a scanned document to an email address, the unit prints out an error page without details, and it has the email address I attempted to send the scanned document to.  I am setup wireless to the rest of the home, and one laptop tied into the printer by a USB for more local access as I set it up.  Looking at the Emanual, it is really very vague on how to set up for email.  Is there anyone that can assist?
2 REPLIES 2
montyseal
I check back in to see if anyone has an answer, none yet.  next I suppose I call in for assistance.
Hi montyseal.
I will be able to assist you.
Please follow the instructions below to set up the scan to email function:
1. Start the Remote UI and log on in System Manager Mode.
2. Click [Settings/Registration].
3. Click [Network Settings] [E-Mail/I-Fax Settings].
4. Click [Edit].
5. Specify the required settings.
[SMTP Server]
Enter up to 48 alphanumeric characters as the SMTP server name (or IP address) for sending e-mail and I-Faxes.
[E-Mail Address]
Enter up to 120 characters for the e-mail address that you want to use for the machine.
[POP Server]
Enter up to 48 alphanumeric characters as the SMTP server name or IP address for sending e-mail and I-Faxes.
[User Name]
Enter up to 64 alphanumeric characters as the user name for the specified e-mail account when a POP3 server is used.
[Set/Change Password]
To set or change the password when a POP3 server is used, select this check box and enter up to 32 alphanumeric characters in [Password].
Specify the settings required for I-Fax reception
[POP RX]
Select the check box to receive I-Faxes.
[POP Interval]
This sets the interval (in minutes) used for automatically connecting to the POP3 server. If there are any I-Fax documents on the server, they are automatically received and printed.
To disable automatic reception
Set [POP Interval] to [0]. When [0] is set, you receive I-Faxes manually. Receiving I-Faxes Manually
Setting up authentication before sending and encrypted communication with the server
Configuring authentication for sending prevents unauthorized users from sending e-mail and I-Faxes. Communication with the server can be encrypted.
[Use POP Authentication Before Sending]
To use the POP3 server for authentication, select the check box.
[Use APOP Authentication]
Select the check box to use APOP to encrypt the password during the authentication process.
[Use SMTP Authentication (SMTP AUTH)]
To enable authentication on the SMTP server, select the check box and enter up to 64 characters in the [User Name] text box.
To specify or change the password, enter up to 32 characters in the [Password] text box.
[Use SSL for SMTP]
Select the check box to use SSL for encrypting communication with the SMTP server. Select the check box for [Verify Certificate] or [Add CN to Verification Items] depending on your needs.
[Use SSL for POP]
Select this check box to encrypt communication with the POP server using SSL. Select the [Verify Certificate] and [Add CN to Verification Items] check boxes as required.
6. Click [OK].
7. Restart the machine.
Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
  • Depending on the network you are using, you may need to change the SMTP or POP3 port setting (Changing Port Numbers). For more information, contact your Internet service provider or Network Administrator.
If you need further assistance with setting up this feature, please call us at 1-800-OK-CANON (1-800-652-2666).
