11-16-2013 04:47 PM
My new D530 is set for front and back printing as OFF yet it still prints front and back even though no instructions to do so.
Could this be a driver problem? They have told me my driver sent with the printer is not correct for Windows 8. I tried downloading one from the sight. It did not load. I can print but stuck in double sided mode even though says OFF. Any suggestions?
11-24-2013 09:01 AM
11-16-2013 05:01 PM
11-18-2013 10:27 AM
Hi ejbpesca.
The 2-sided controls on the control panel of the machine are for the copying function. You do have to turn off the two-side printing feature in the driver. Please follow the steps below to perform this operation:
I hope this information is helpful to you. If you need any further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
11-24-2013 09:00 AM
I cannot find a "finishing tab" in the location described.
11-24-2013 09:01 AM
My printer is not 500 but rather 530
11-24-2013 09:08 AM
It is under properties, not "finishing."
01-24-2014 08:49 PM
I have the same problem on my iMac. How do you do this on a Mac?
01-26-2014 03:25 PM
Hi jessasdad!
In the Mac OS X operating system, you will need to turn off 2-sided printing in each application. Please follow the steps below:
I hope this information is helpful to you. Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
01-26-2014 04:19 PM
The 530 printer and I guess others leads one to intuitively go to the led screen printer menu for settings, but that is only one part of the functions. It is the computer's software that must be adjusted too for single or double sided printing. I think the single side choice is under properties on most computers. What threw me off was this is the first printer of very many I've owned that was set to double side printing from the start.
Must say the printer is doing well and so fast I was waiting on it to make clunky noises and print but it had already printed in a few seconds. It is very nice to be away from ink jets that dry out even if not used.
02-20-2014 09:46 AM
I am unable to find where to change this setting. I have tried the instructions above but there is no selection for changing 2-sided printing under the finishing tab.
I am running on a MacBoon Pro, using Parallels and Windows 7. I know how to change in Mac programs but cannot figure out how to disable 2-sided printing in Windows 7 under Parallels.
Help.
