06-12-2013 01:03 PM
I have recently purchased a Canon DR-G1130 ImageFormula high speed scanner. Installed the driver and other software onto a Windows 7 system with 2 gb ram. When I went to scan a large document it only scanned at 30 ppm. I checked the settings of the software and the scanner settings (set a high speed). How do I get it to scan at its advertised speed of 130 PPM!?!?!
04-21-2015 02:32 PM
Not sure if this is the answer, but if you scanned using OCR, or optimized on your initial scan it scans slow. I always find it best to scan, then OCR alot faster
