Reply
New Contributor
Re: Scanning problem. Receive error message: cannot write file. Code 10,242,7. Please help
I renamed that file but nothing happened.
Then installed .net 3.5 but my problem is steel remained.
New Contributor
[ Edited ]
Ok. You have to rename WMPHOTO.DLL and  then install .net 3.5. After that, try to scan. Make sure that .net 3.5 is installed looking in add/remove programs in control panel.
Greetings!
[MOD NOTE: Removed all non-English content per FORUM GUIDELINES]
New Contributor
I renamed that file and then installed .net 3.5 for the second time but it had no effect.
New Contributor
i buy canon scanner Mg4240 but when i scan any documents then 13,242,0 code is coming , how i can solve this problem
New Contributor
i have try your step but still got the same problem.
New Contributor
hi i keep getting unable to write file code 13,242,0
can you help me solve this.
New Contributor
Hello and I soon have this problem.
I tested all the methods described above. No effect. No update to the operating system. I'm using an operating system Windows Embedded POSReady. I use a scanner  canon lide 120
New Contributor
[ Edited ]
If you are using Windows XP Pro SP3 in POSReady/WEPOS mode or Windows Embedded version only, the problem is a specific update patch # KB4074852. This patch changes important system files. After updating, many apps are not working properly (problems with .NET-based apps, scanning functions, video conversions, wifi adapters etc).
The only solution is to ignore this patch. If you have it installed, you need to uninstall it.
powered by Lithium
