04-06-2018 04:38 PM
I just recently purchases an image class duplex.
Printing was great at first...today I had to print something on the flip side of an already printed item. I tested it to see where the picture should be. Figured it out, great. And so I hit the print for mulitple copies. Everyone of them was flipped around opposite of where it should have been as per my test.
So I figured it was because I chose multiple prints (which still does not make sense). I turned the paper back around and hit print again. They came out correctly this time - except the last copy. The printer flipped the paper.
I'm not thrilled with this, because I am not wanting to waste toner or paper every time I do a multiple print.
Could someone help me with this issue?
Thanks.
04-19-2018 09:21 PM
Hi - Thanks for checking. I figured it out. Should have posted that I did. Thanks a bunch!
04-06-2018 04:52 PM
Hi, LuAnneD!
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using and the exact model of the printer you are using.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help via Email at http://Canon.us/SupportCF
Thanks and have a great day!
04-06-2018 10:08 PM
Hi, Jason,
I have Windows 10 Home. The printer I have is the color ImageClass MF735Cdw.
It's not time sensitive because I will be able to work around it for a bit. But I prefer to have it working properly. 😉
Thanks.
04-19-2018 04:30 AM
Hi, LuAnneD!
Thank you for your response.
Could you also let us know what program you are printing from? Also, if you print from other programs does the same issue occur?
Please note, Canon's Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please use the link below to reach our friendly Technical Support Team:
http://Canon.us/ContactLI
04-19-2018 09:21 PM
04-18-2018 11:12 AM
04-18-2018 12:05 PM
Hi carana,
To open the cover to replace the ink cartridges, please follow the steps in the On Line Manual:
http://ugp01.c-ij.com/ij/webmanual/Manual/M/MG2500%20series/EN/BG/bg-ink1000.html
04-22-2018 06:29 AM
04-22-2018 11:27 AM - edited 04-22-2018 11:28 AM
Canana,
Sometimes we are the problem, that's for sure. I've used so many different printers I should have realized: all I needed to do was go into the printer properties and tell it not to print duplex. Simple solution, duh moment.
Good for you for gettin away and carrying on!
