04-17-2017 09:28 PM
Hi experts,
my MB5360 will not print and is showing error code 1007 - Paper has run out.
This is a problem because there is paper, it is loaded correctly and it is programmed correctly for the A4 plain paper that i am using.
I have turned the unit on and off and have reprogrammed the paper type. Im not sure what else to do? Has this happened to any of you? Will i have to send it to a repairer?
Thanks in advace for your help 🙂
Kristie
05-08-2017 10:36 AM
Hi kristietownsend,
To clear the 1007 error, please follow the steps outlined in the On Line Manual:
http://ugp01.c-ij.com/ij/webmanual/ErrorCode/MB5300%20series/EN/ERR/1007.html
If the 1007 error persists, please contact our support group using the following link:
http://Canon.us/ContactLI
