09-07-2017 12:20 AM
MF8580Cdw is not scanning. It has only just started producing this error everytime I follow the following instructions:
Click Scan on machine, remote, and it says waiting
On my computer I open up Toolbox and click scan B&W, it brings up Select Source: Platen Glass. No Auto Mode.
This has only started happening recently. What is the problem.
Then when I click scan. It says Error Code 255,0,0 Terminate Scanner Driver.
Very Frustrating.
Regards,
Rose
04-18-2018 04:19 PM
Hello, jvannghi,
Thanks for the updated information!
The Canon Community Forums aren't intended for immediate support. If you're in need of urgent assistance, please call 1-800-OK-CANON (800-652-2666), and our friendly support team will be happy to help! They're available weekdays between the hours of 10am to 10pm (ET).
04-18-2018 04:38 PM
04-18-2018 07:30 PM
Canon tech helped me update drivers and reinstall the MFtool and works now. He was baffled.
Thanks anyways!
05-25-2022 07:37 PM - edited 05-25-2022 07:38 PM
What I did was cleared all the settings on the printer itself and that worked.
I spent 2 hours with a Canon rep and he was not able to figure out what the problem was, after two ours all he recommended was a firewall install, which it did not make any since. After we hung up I even tried it with the USB cable option and would still not work. Then it occured to me to do a reset on the printer and that worked! I hope that this helps anyone having issues with their Canon printers.
