11-24-2014 02:59 AM
How to fix this so my printer will print? I have Windows 8.1. Thank you for your help.
11-26-2014 11:40 PM
Hi rba.
I will be glad to assist you.
The file that you download from the Canon website is .ZIP file. When you select [RUN], it unpacks the setup folder. Please disconnect the printer from the computer and follow the instructions below to install the printer:
1. Open your [Downloads] folder.
2. You will see two icons with the name: MF8500C_Series_PCL_MFDrivers_W64_us_EN_1.exe. Double-click on the yellow folder icon with this name.
3. In the folder you will see two listings for [Setup]. Double-click on the [Setup] that has the type as [Application].
4. The "MF Drivers Setup Wizard" will open. Proceed through the steps and restart the computer.
5. After restarting the computer, connect the USB cable and allow the installation to complete.
6. Print a document.
I hope this information is helpful to you. Should you need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
