04-25-2018 12:59 PM
We had a problem with a vertical line and dots down the left side of the paper when printing, copying was fine. I cleaned the machine and was able to get rid of the line but the dots are still there. Every inch or so. Can someone help me resolve this issue please?
09-08-2020 04:33 PM
After working with Canon support, we isolated the issue as one of a leaky toner cartridge. Toner would leak, stick to the drum, and dashes or artifacts would be rolled onto the paper. I had hoped for a gratis replacement, but because the cartridge was a starter, Canon was a bit reluctant. I replaced it, and the others, with "full" cartridges and the issue was solved. Pricey but effective. The MF733Cdw has been largely effortless.
05-02-2018 04:32 AM
Hi nejiwhopper
I recommend cleaning the Fixing Unit and the Transfer Belt to resolve the issue. Please click HERE for instructions to clean the Fixing Unit. Perform the following steps to clean the Transfer Belt:
Transfer Belt
02-16-2019 12:46 PM - edited 02-16-2019 01:28 PM
I had the same problem. I have had the machine for less than one year, and printed at most 10 color jobs during that time. I noticed it today when I forgot to switch color to black and white.
I ran the fixing and cleaning functions three times, but the red hash marks persisted. They were located on the right side of the front side, and the left side of the rear side (when duplexing), of prints, approximately one inch apart vertically.
I scanned a print copy here:
I then rocked all of the cartridges and printed five copies. By the third or fourth, they were gone. I ran another copy now, and they still are gone. Problem solved:
Thanks James_C.
02-23-2019 02:07 AM - edited 02-23-2019 02:15 AM
Unfortunately, they have since returned. I did not print color since I last posted. The cleaning + shaking the toner cartridge worked again, but the problem appears to be recurrent. Any ideas for a solution, other than me shaking the cartridge every time before I print in color?
03-05-2019 04:28 PM
Hi nyuk.
Since the issue persists, we will have to recommend that you call our telephone support group. Please call 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays). A representative will be able to further assist you.
09-07-2020 04:17 PM
I have black specs down the left side of paper each time I print. I have cleaned everything I could think of to get rid of them including the maintanence cleanings. Is there anything else I can do
09-08-2020 04:33 PM
