10-24-2023 05:08 PM
MF644cdw leaves streaks on plain paper. just replaced toner( not canon) but toner I have used before and did not have this issue until toner was low. leaving blue & yellow streaks horizontal from top to bottom. Print is just fine on issues with print quality. Not sure if this printer has a drum since the help on canon site is not very good.Looking for some help to resolve this before I buy another printer. This one is about 3 years old.
10-24-2023 06:08 PM
When I have had this issue on my printer it was the drum that was the issue. Either ink was leaking from the edge of the drum or some junk got stuck to the roller. Might want to check that out. I have usually fixed it by replacing the drum. Especially if the lines are at the edges of the paper. When there were dots in the middle of each page I was able to carefully clean the spot off of the drum and it worked fine afterwards.
11-07-2023 09:22 PM
Where is the drum and how do you get to it?
10-25-2023 03:10 PM
Thanks I have been looking for the part for this MF644cdw printer but not sure if there is a drum in this printer.
11-07-2023 11:18 PM
Evidently your printer toner cartridges are different than mine. they have the drum included. It's not seperate. I saw something here that might help, https://community.usa.canon.com/t5/Office-Printers/MF644Cdw-yellow-streaks/m-p/292277
