02-05-2021 08:19 AM - last edited on 02-11-2021 08:56 AM by Danny
Recently, documents or spreadsheets in Word/Excel plus documents off the web print only random lines. If I save the doc in PDF format (and indicate print image in printer settings), the doc will print. Running OS 11.2 - anyone else experiencing this problem.
02-06-2021 09:32 AM
Are you sure about the model number? Canon does not appear to make a "MR632C"
They do make a MF632Cdw.
Support | Color Laser | Color imageCLASS MF632Cdw | Canon USA
Have you upgraded your OS recently?
If your printer worked previously under a earlier version of MAC OS and you upgraded to BugSur 11.2, you may need updated drivers for the printer to work correctly. This might require that you remove the printer, uninstall the old drivers and re-install the device using newer drivers.
~CarePaks Are Worth It
02-06-2021 09:32 AM
02-08-2021 02:13 PM
