04-29-2014 08:06 AM
After the most recent Windows 8.1 update (installed yesterday), I can no longer scan documents. the scanning process starts normally. However, after scanning a random number of pages, I receive an error, and the scanning process is terminated due to the error.
I get this message:
Cannot communicate with the device.
The cable may be disconnected, or the device may be turned off.
Check the device status and try again.
Scanner driver will be terminated.
Code : 155,0,0
I have uninstalled all of the drivers and software and reinstalled them. This did not correct the problem.
05-04-2014 10:15 AM
Hi NotMe.
I know this error is frustrating and I will be glad to assist you.
Since you have uninstalled and reinstalled the drivers, and the error persists, please follow the instructions below:
1. Open the Windows desktop.
2. Right click on the MF Toolbox icon and click properties.
3. Click the Compatibility tab, then click "Change settings for all users".
4. Put a check next to "Run this program as an administrator", then click Apply and OK.
5. Click OK again on the properties screen.
The MF Toolbox should operate normally.
I hope this information is helpful to you. Should you continue to experience errors, please contact us at 1-800-OK-CANON (1-800-652-2666).
05-07-2014 07:33 AM
This did not work.
Scanning will no longer even start. I now receive an error that states:
MF Toolbox that is supported by the scanner you are using may not be installed on your computer.
Install the appropriate MF Toolbox, and then perform the operation again.
05-07-2014 04:21 PM
Thank you for your reply.
Since the error persists, after uninstalling the drivers and software and running the program as an administrator, I recommend that you contact us at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00AM - 8:00PM EST. The real-time feedback of a live technical support call would be very beneficial in this case.
02-04-2016 12:01 PM - edited 02-04-2016 12:04 PM
I have the exact same error with my MF4890DW, and have tried your solution to no avail.
The fax portion of the machine works perfect though.
All I get is a busy signal at the phone number you posted above.
BTW I'm running windows 7 and my MF toolbox is version 4.9
