11-28-2017 08:18 AM
Hi Canon Comunity
I need your support to fix an issue that I have with the printer MF216n connected to the fax.
I can send and receive Fax without issue but the printer wont print it no matter what I do.
I tried to use the memory and lunch the printing by deactivation the memory option nothing still have the same error message of Cas 1 no paper A4 Ordinary.
I tried to put paper on both Cassette 1 and Bac FM but nothing.
In the error message the resume buton is gray and I can't use it I can only cancel the printing of the fax and delete the fax.
is there any solution to my issue ?
BEst regards,
HichLao
11-29-2017 03:55 AM
Hi HichLao.
Please verify that the paper settings on the machine are set for A4 size paper by following the instructions below:
11-30-2017 03:39 AM
