Reply
New Contributor
Re: MF Toolbox doesn't work on Windows 10
I too am having the same problem after having upgraded to windows 10.  I am not exactly sure how to uninstall the drivers as you and others have suggested.  Could you possibly give a few more details?
thank you
New Contributor
I actually spent 90 minutes on with canon support today.  It is amazing that they are unaware of this problem and that they could not help me fix it.  Pretty pathetic.
Occasional Contributor
[ Edited ]
Marc before doing anything check your windows 10 settings
I am pretty sure everything is fine, the drivers the toolbox everything just WIndows 10 settings is all you need to change.
I truly believe the default setting has to be Check that Local System account , and Allow service to interact with desktop is checked. Hit apply.
The defauylt setting is set to login user name/ password when it shoudl be  Allow service to interact with desktop
I truly believe that one tick will fix all...
Piers_A Had the answer the entire time all the rest is useless I am pretty sure...
Here is what he posted...
This simple fix I found online worked for me:
Start> in the run box type. Services.msc
Scroll down to Windows Image Acquisition (WIA)
Right click, select Properties
Check that Startup type is set to Automatic
Click Log On Tab
Click Recovery...Click on window next to First Failure, Scroll to Restart the Service. Hit apply.
New Contributor
[ Edited ]
Thank you for that information.  I just tried it,but the computer still gives an error message that it cannot communicate with the scanner.  It did not work. Smiley Sad
Yes, unfortunately, neither Piers_A nor aholic solutions worked for me.
Since I really need the scaning working, I am not upgrading another laptop, which I have dedicated as "server" of my LAN.
Smiley Sad
New Contributor
I have the same very frustrating problem!  Pleae fix this problem!
New Contributor
I followed your instructions and it works! However, after not using my printer / scanner for a couple of days, I need to uninstall, reboot windows 10 and install MF Toolbox again. Do you have any advice?
Did use an uninstaller like Revouninstaller first?
New Contributor
Hello,
I am French. I have a MF8580cdw, and in august I upgrade my computer from Windows 7 to Windows 10. Since August, I don't scan with my MF TOOLBOX utility I just can print.
Before, I bought my MF 8580, I had SAMSUNG CLX 3175 FW and I scanned with SmarThru 4 Utility. Now, I use Smarthru 4 Utility for my MF 8580 SCANNER. I just change the SCANNER adress.
The interface of the Smartru 4 is more friendly than MF Toolbox and it's a freeware
Best regards
GARO
New Contributor
This actualy worked.
Thank you!
powered by Lithium
