Reply
New Contributor
Re: MF Toolbox doesn't work on Windows 10
This worked great for me also Piers-A..thank you
New Contributor
That's good to know thanks.  Easier than buying a new printer!
dcp
Occasional Contributor
Since installing Windows 10, MF Toolbox for my Imageclass4570dw doesn't work. I'm able to print, but scanner doesn't work. Driverdetective wasn't able to help. My computer savy son-in-law was able to scan a document in .jpg after spending about an hour trying different approaches (but PDF scan option didn't exist). Now, I can't scan anything (again).
Canon, please get this fixed.
[ Edited ]
I tried Kudos but didn't work so here's a reply
Everything I did
I swear the fix is hit right on the head by you (Piers_A)
I thank you
For some reason Windows 10 WIA service default setting is to log onto scanner...
When I swtiched it too
Check that Local System account , and Allow service to interact with desktop is checked. Hit apply.
It worked like a charm
Thank you for saving more aggravation but you found the culprit
Thank you
New Contributor
Thanks aholic.  I hope the original solution provider, Captret, is following this!
Don't know but if I were Cannon administartor I would move this to number1 spot...
All the others including mine are useless if these setting aren't correct hopefully everyone reads this one first...
I again went through all of the motions (and emotions) but to no avail.  The toolbox will not install on my windows 10 pro.
Spoiler
My printer/scanner is a D420.  Maybe the work around works on some scanners and not others??  Seems like Canon needs to get on the ball.
New Contributor
Thanks - this worked for me and was really quick to do - no re-installation necessary and I've now got scanning from the autosheet feeder too.
New Contributor
Thanks for this, it worked for me too. I have an mf4370dn
[ Edited ]
MF6580PL. Thanks Piers_A (19Aug2015)This worked for me.
Failure to scan - or, more bizarrely, taking up to 5 minutes to start scanning - started for me In Win7 but became impossible in Win10.
I noticed that scanning worked if the printer was turned on before booting the PC, but not if turning on the printer when the PC had booted.
I had noticed that I got strange WIA errors on booting. They have now gone too.
Postscript: the problems came back. Grr.
powered by Lithium
