MF Toolbox doesn't work on Windows 10
mj1856
I have a MF4570dn, and recently upgraded from Windows 8.1 to Windows 10.
I can no longer scan using the MF Toolbox utility.   I had MF Toolbox 4.9 installed before the upgrade, and it worked just fine.  After the upgrade, I get "Cannot communicate with the scanner" error dialog:
I thought I would try to reinstall the MF Toolbox utility, but there are two problems.
1) The downloads page shows no downloads for Windows 10 for this printer. This should be updated.
2) I downloaded the one for Windows 8.1, and tried to reinstall, but it just hangs at the "Processing Installation" screen:
I've also tried to uninstall the existing MF Toolbox first, and it also hangs at this same dialog.
I've also tried various other things without success:
- Connecting via USB instead of Network.  It detects the scanner, and MF Toolbox can switch to that device, but it still gives a communications error.
- Trying the built-in Windows Scan app instead of MF Toolbox.  It uses the WIA driver.  It barely starts to scan, then immediately cancels.
Please Canon - forward this to your engineers and provide a fix asap.  I cannot use my scanner on Windows 10.
(I can use the printer functionality just fine.)
Thanks.  My model's links are different, but the new software appears to work.
https://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_...
Also, to get the old toolbox uninstalled, I had to reboot into safe mode.  Otherwise the uninstaller just hung.  Then booted back into regular mode, removed all traces of the existing printer, then reinstalled the new software and it works great.
435 REPLIES 435
Nym
Hello there! I have exactly the same problem. I use a Sruface Pro 3.
Please Canon, you must fix this ASAP, I need to use my scanner on my work everyday!
alexbailey
I have the same problem. I can print, but cannot scan now that I have Windows 10.
I upgraded to Win 10 on six machines. five machines can print. One can not load the driver and can not print.
No machine can scan.
I hope this gets fixed rapidly.  I really need the scanner.
cyw127
Same here. Please fix this soon Canon!!!!!
vagabondSteve
I Upgraded to Win 10 today, so I had this problem too.....however......
OK, so this isn't an exact substitute for the Toolbox....I have an MF4770n.
I did find Win 10 Drivers on this site, so maybe they are new additions.
Download and install the latest drivers for your MF4770n from this site. Restart your PC. Test printing.
Then go to the  Windows App store, search "scan", find "Windows Scan" app, install.
At MF4770n load a doc to scan, select Remote Scanner,
At the PC, open Windows Scan App - it found the 4770n instantly on my system.
Use the drop down menus to select source, output etc. You can preview platen scans, not auto feeder docs.
Doc feeder worked to scan a 5 page PDF first try!
Works for me, hope it does for you.
Steve
BTW: The driver for Win 10 x64 is
MF4700_Series_MFDrivers_W64_us_EN_2.exe v20.90
for my Canon, I hope there is one for all of you!
TheTasmar
After messing around with this myself I got this to work but doing the following:
1. turn off printer, if you don't when windows 10 boots it may auto detect it and install (which I found screws this all up)
2. uninstall the MF Toolbox and driver if installed then reboot windows 10
3. After reboot and login turn printer back on and make sure it's connected to network (test ping and config page)
4. Install driver, it should detect printer but if not try entering the IP, and make sure MF Scan  appears in notification area.
5. Install MF Toolbox for windows 8.1 (v4.9)
6. add inbound and outbound firewall rules for:
%ProgramFiles% (x86)\Canon\MF Toolbox Ver4.9\MFTBOX.exe
%ProgramFiles% (x86)\Canon\MF Toolbox Ver4.9\TBOXCFG.EXE
%ProgramFiles%\Canon\Canon MF Network Scan Utility\CNMFSUT6.EXE
7. modify the MF Toolbox configuration (just go in and then press OK)
8. On printer test scan and it should show your computer
fnkhan
I have been having similar problems. Uninstalling and reinstalling MF toolbox didn't work.
Canon, please update the driver.
I found the solution to this problem. You want to remove other driver folders in Windows/Twain_32 directory. I manaully removed Creative folder and it worked. I guess my creative cam doesn't work anymore, but that was coming for a long time.
