12-08-2022 05:04 PM
I’m having a weird problem with my Canon MF264dw printer/scanner.
The problem is that when I go to scan documents placed in the ADF (Automatic Document Feeder) the Canon MF Scan Utility on the problem PC cant “see” the documents in the ADF.
If I keep the setting on "Auto Mode" it just scans a blank page from the Platen.
If I use the ScanGear option and select "Feeder" it fails with a Canon error message: “Scangear MF can’t communicate with the scanner” Code 155,0,0.
Background:
There have probably been 5 or 6 Windows Updates since the ADF last worked and I think one of them was going from Windows 10 21H2 to 22H2.
Any thoughts on how to get communication to and from the printer ADF through a USB connection?
12-10-2022 05:17 PM
12-10-2022 05:17 PM
I figured it out: Bad USB cable.
Replaced it. Works.
