11-27-2016 07:44 PM
How can I turn off the feature that auto rotates scans? It does it both through the auto feed and when I manually scan. The printer thinks my page is upside down and rotates it 180 degrees. This is very annoying.
02-02-2017 07:22 PM
Hi jlknapp.
I will be able to assist you.
You will need to access the Image Processing Settings in section (1) of the document settings of the Canon IJ Scan Utility:
Click the right-arrow, to the right of [Image Processing Settings], and then disable the [Detect the orientation of text document and rotate image] option.
If the issue persists, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be able to further assist you.
02-10-2017 01:43 PM
Thank you!!!
