10-16-2017 02:57 AM - edited 10-18-2017 12:45 AM
Printing wall wraps on a media type I have not used before. The wall wraps are different sizes, but all are over 8 feet high. They are printing short by 1.50" to 2". If I was confident they would all print the same incorrect length, I could simply adjust the height but this is less than ideal. I am using an IPF9400 on a Windows 7, 64 bit system, printing by exporting to the Adobe CC print plugin. I have had a similar problem with heavy canvas (67" X 44") but never with papers. This media is a paper, adhesive and release liner and a full roll weighs over 60 pounds. Is it the weight of the roll that is making a difference in how the media feeds through the printer? Small test prints were exactly to size. This issue is showing up only on the long prints.
10-17-2017 08:30 AM
Hi, Tjrvaphotog!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, search our knowledge base or contact our US-based technical support team at http://canon.us/SupportCF
Thanks and have a great day!
10-17-2017 05:32 AM - edited 10-18-2017 12:47 AM
A little help would be appreciated. Thank you in advance.
10-17-2017 08:30 AM
Hi, Tjrvaphotog!
