10-24-2017 07:46 PM
I am trying to print on 17x22 cut sheets and want the printable area to be 16x21 (1/2" border all around). It seems one of the sides must have a 23mm border.
Is there a way to fake out the printer by creating a paper size or something so I can do this? Or another solution? I can't believe this is not possible somehow!
Using Windows printer drivers, and am trying to print a 17x22 pdf, which has a 1/2" border all around so the printed image is 16x21.
Thanks!
10-25-2017 10:55 AM
Hello.
The minimum required margins for cut sheet media cannot be adjusted. A minimum of 3mm on the top and sides is required, and a minumum of 23mm on the bottom margin is required in order to be able to perform the printout.
09-28-2018 05:52 AM
09-28-2018 10:14 AM
Hi dubravkoj,
The minimum margins cannot be changed.
09-28-2018 10:22 AM
