10-23-2013 02:20 AM
On my WIndows 8 desktop computer, I have an MX452 printer. My Devices and Printers window shows a Canon MX450 Series. I also get a recurring optional update notification for the "Canon - Printers -Canon MX450 series FAX" even though I've sucessfully installed it several times. It has a release date of September 2012. I noticed that on the Canon site, there are three drivers for the MX450 Series dated 10/1/2013. Should I be manually installing these drivers?
If I should install them, I do I need to install all 3?
File Description Date Size
MX450 series Mini Master Setup (Windows 8.1/8.1... | 10/01/13 | 24.38 MB | |
File Name: mast-win-mx450-1_0-ucd.exe This file contains the Setup application, MP Drivers and IJ Network Tool necessary for setting your printer up on a network. | |||
MX450 series MP Drivers Ver. 1.00 (Windows 8.1/... | 10/01/13 | 18.70 MB | |
File Name: mp68-win-mx450-1_00-ejs.exe This file is a driver for Canon IJ multifunction printers. You can install the following items of the software: MP Drivers: The driver for Canon IJ multifunction printer. IJ Scan Utility: The software that allows you to easily scan photos, documents, e... | |||
MX450 series XPS Printer Driver Ver. 5.65 (Wind... | 10/01/13 | 14.20 MB | |
File Name: xp68-win-mx450-5_65-ejs.exe This file is a printer driver for Canon IJ printers. XPS printer drivers support 16-bpc printing, which enables more smooth gradation printing than the current drivers (8-bpc printing). |
11-03-2013 03:34 PM
Hello JeffL.
You can download and install the Mini Master Setup. This setup contains the MP Driver and IJ Network Tool for wireless use.
The optional XPS driver can be installed after the Mini Master Setup or MP Drivers are installed if you wished to use the printer with a program that supports an XPS printer.
11-30-2013 03:16 PM
Michael's answer to JeffL didn't explain why we keep getting product update notifications even after installing the updated drivers. Will installing the optional XPA driver make this stop?
01-03-2016 01:10 PM
01-04-2017 11:47 AM
CANON Management,
Please communicate driver & file download purposes & differences on the download page so we know the difference between each type of download and can make an informed decision without having to go to the forum. This is not an efficient way to get the information we need.
01-04-2017 12:05 PM
Hi bonniegiddens!
Thank you for reaching out to us, we're happy to help!
When you go to the Canon site to download drivers and software, everything has a description for what the file is, and what it does. You just have to click the "Select" button and it will give you all of the information. The site will even let you know if the software is optional.
You can find the software and drivers by clicking HERE
If you find that you need additional help, our US-based technical support team is happy to help at 1-800-OK-CANON (800-652-2666) from 10am to 10pm (ET) Monday through Friday.
We hope this helps
12-28-2021 01:32 PM
Sorry to say this but no, the information is incomplete and/or confusing. For instance, it doesn't say that we must install the MP driver before the XPS driver allowing 16bpc. I had to dig the Web and ended up here in order to know such an utterly basic information, that the MP driver must be installed before hand ("must" it ?...), and it should be mentioned on the download page, especially when both drivers seem to provide the same utilities like network tool etc (are they?)... Not customer friendly at all!
12-28-2021 01:48 PM
Hi, Ulmo!
This post is rather old, and things have changed quite a bit since then. You'll find all of the most up-to-date software and drivers within your My Canon Account at canon.us/account
If you're outside of the United States, you'll want to visit the site for Canon in your country for support options. Get started at canon.us/globalsupport
12-28-2021 02:17 PM
The issue is not old, it's still in effect, thus it's still relevant. As I wrote, it's still confusing. Same thing in 2021 as it was in 2017, and that's what should be of concern here 😉
