07-13-2016 05:16 AM
I have replaced the one colour in my printer MB 5340 It keep giving me the error B504 I have swithced the printer of and I have used origanal catridges. Can't get it to even move the catridges so I can get it out to see what is going on.
Lizette
07-13-2016 07:25 AM
Found this via Google:
"Service Notice: MAXIFY B504 Error
Thank you for using Canon products.
Some replacement ink tanks sold for the Canon MAXIFY series printers which are not manufactured by Canon may cause a B504 error to be displayed, causing the printer to shut down. In such cases, even though the printer's ink supply system is working properly, the design of the non-genuine ink tank is obstructing fluid ink supply to the print head, causing the B504 error. Please be advised that the repair for this error caused by non-genuine Canon ink tanks is not covered under warranty and, therefore, repair or exchange charges will apply."
Also this (not your model, but maybe applicable):
07-13-2016 09:38 AM
But she says:
"...and I have used origanal catridges"
07-13-2016 09:41 AM
I know. See the link:
07-13-2016 09:43 AM
The part you quoted was all about non-canon cartridges.
07-13-2016 09:46 AM
You may be correct if there is such a thing as "original non-Canon cartridges"?
I always assumed original cartridges were the cartridges that originally came with the device.
Whatever; either it helps the OP or it doesn't.
07-13-2016 09:51 AM
No big deal. I think of it like "factory original" car parts i.e., buying it from the dealer as opposed to buying it at Napa.
01-12-2017 08:39 PM
I can not see the whole response about the fix of the error code b504. Could you repost?
01-12-2017 10:26 PM
See this:
06-29-2019 09:17 PM
Thanks for posting. This worked for me. I am not using OEM cartridges. This issue is certainly an issue with the printer. I also think that we have to print a couple pages to the printer at least once a week to cut down on the cleaning cycles. I had not done so for about a month and that is when I got the error code.
