How do I use the single page feed on my Canon MX340?
segurry
I am trying to figure out how to feed single pages into the Canon MX340 from the slot on the top. How to make this happen?
1 REPLY 1
Ramona
Hello segurry,
To feed documents into the automatic document feeder (ADF) of the printer, please follow the instructions below.
Loading Documents in the ADF
You can load documents to copy, fax, or scan in the ADF.
Note:
To scan a document at optimum quality, load it on the Platen Glass.
  1. Make sure that any original has been removed from the Platen Glass.
  2. Load a document in the ADF.
    1. Open the Document Tray.
    2. Insert the document in the Document Tray (2) until you hear a beep sound.
      Load the document WITH THE SIDE TO SCAN FACING UP in the Document Tray.
      Note: When you set the alarm to be silent in Device user settings of Device settings, the alarm will not beep even if the document is inserted in the Document Tray.
    3. Adjust the Document Guides (3) to match the width of the document.
      Do not slide the Document Guides too hard. The document may not be fed properly.
Hope this helps!
Enter for a chance to win!
April 20th-28th
