Reply
Highlighted
New Contributor
Canon imageclass mf236n Fax Confirmation
Is there any way that I can get my printer to print a fax confirmation?
Thanks!
Re: Canon imageclass mf236n Fax Confirmation
Hello RapidPrt,
Your imageCLASS MF236n has a report called the "TX Result Report" which will give you the results of each FAX transmission.  It shows you the Job No., Address, Name, Start time, Call length, Sheets and Result.  To set the printer to automatically print a TX Result Report using your MF236N's operation panel, press <Menu> -><Output Rprt.> -><Report Settings> -><Fax TX Result Report> -><On>.  When you select <On>, a part of a fax document can be included in the report. Tap <Include TX Image> to <On>.
If you need immediate assistance and you're in the USA, please click http://Canon.us/ContactCF for our US-based support. If you're outside of the US, please click http://Canon.us/4xf7 for support options.
powered by Lithium
