Reply
New Contributor
Accepted Solution
Canon MF4770n scanner not working on Windows 10 x64
The printer works fine without any trouble, but Toolbox (to scan documents) isn't working. It doesn't detect the scanner. Is there an update for this printer to support windows 10 soon? Or is there another way I can go about doing this?
Thanks
New Contributor
Re: Canon MF4770n scanner not working on Windows 10 x64
I have same problem with my MF4350d scanner.  If anyone has figured out a way to get Toolbox or scanner to work with windows 10, please post.  Printing is not a problem, but I need to use the scanner too.
New Contributor
I don't think your printer has networking, but if it does, my temporary solution was to install the network software on my second computer and just use network scanning to be able to scan.
Occasional Contributor
Upgraded to Win 10 today, so I had this problem too.....however......
OK, so this isn't an exact substitute for the Toolbox....
Download and install the latest drivers for your MF4770n from this site. Restart your PC. Test printing.
Windows App store, Windows Scan app, install
At MF4770n load a doc to scan, select Remote Scanner, open Windows Scan App
USe the drop down menus to select source, output etc. You can preview platen scans, not auto feeder docs.
Works for me, hope it does for you.
Steve
New Contributor
[ Edited ]
After having used Canon's ToolBox and Windows SCAN, I don't see any point to loading the ToolBox.  SCAN is already part of Win 10 and is more intuitive,
New Contributor
[ Edited ]
The drivers have been updated for WIndows 10. Scanner works perfectly over network.
New Contributor
I figured out how to fix both the Toolbox and scanner.  It simply requires that you uninstall both the current drivers and the Toolbox, reboot the computer, and reinstall the drivers.
I tried that and still can not scan from my latop. Any advice?
New Contributor
That worked for me. Thanks!
New Contributor
I solve this problem on my Imageclass MF4350d by dong the following:
 It simply requires that you uninstall the current drivers, remove the printer, disconnect the printer USB cable,  reboot the computer, and reinstall the drivers, connect the printer USB cable and reinstall the printer..I used Print Management  app to uninstall current drivers.Both the tool box and Windows Fax  and Scan program worked after these steps.
 I hope it helps you.
powered by Lithium
