02-25-2014 08:38 PM
I can print and I can fax - but I cannot get the scan function to work on my home network. It says "cannot communicate" when I run the toolbox. I moved the printer and scanned using a USB cable just fine (changing the settings to turn USB on). But when back on the network - nothing.
I am on Windows 8.1 (64 bit) and I do have another scanner (Epson) plugged in via USB which continues to work fine - but it doesn't have an automatic feed so I prefer to use the Canon.
I installed the latest firmware on the device as well - but no change.
03-04-2014 02:51 PM
Hi HarryJ!
When scanning over the network with the imageCLASS MF4890dw, you will need to register the scanner in the MF Network Scan Utility. To perform this operation, please follow the steps below:
Next, scan a document, using the following steps:
I hope this information is helpful to you. If the error persists, please contact us at 1-800-OK-CANON (1-800-652-2666)
09-09-2014 07:14 PM
I am having the same issue with my laptop. I have deleted everything, downloaded the drivers and tool box from the CanonUSA.com website and spent 3 hours on the phone with tech support. The drivers are there, it prints and faxes perfectly, it just doesn't recognize the scanner and I don't have a USB cable to try that route. I am running Windows 7 and have no other printer devices hooked up to my laptop.
09-15-2014 11:16 AM
Hi Stely54.
What is the exact error message that you receive when you attempt to scan a document?
I look forward to your reply. Should you need immediate assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
09-15-2014 04:14 PM
A supported scanner is not installed.
Please install a supported scanner, and then restart Toolbox.
09-26-2014 05:57 AM
Thank you for the reply stely54.
Please follow the instructions below and verify if you experience the same error:
1. Open the Windows desktop.
2. Right click on the MF Toolbox icon and click properties.
3. Click the Compatibility tab, then click "Change settings for all users".
4. Put a check next to "Run this program as an administrator", then click Apply and OK.
5. Click OK again on the properties screen.
The MF Toolbox should operate normally for scanning.
I hope this information is helpful. If the error persists, please contact us at 1-800-OK-CANON (1-800-652-2666).
10-08-2014 10:06 AM
Hello,
I'm having the same problem, even after trying your above suggestion re adding permissions to run as administrator.
When opening MF Toolbox, the error message is "A supported scanner is not installed. Help!
07-30-2015 06:13 PM
The scanner doens't show up in the list inside the Canon MF Network Scan utility.
09-25-2014 01:43 AM
Same problem on Windows 7.
04-24-2016 04:37 PM
I have the same problem, and I am on window 10. It happened very recently. I noticed that there appeared some automatic driver installation: a driver mf44scn.inf was installed on 4/12/2016. I think, that was when the problem started.
My printer is working fine, but not the scanner.
Looking forward your help. Thanks
