Reply
New Contributor
Re: Black vertical line on scans
I followed your instructions. Still getting line. There is a tiny little black spec on the top white portion that sits on the glass when closed. Could that be it. I tried glass cleaner. It would not come out.
New Contributor
That worked for me! Thanks.
New Contributor
I just started to have this issue.  I have run the "fix/clean" twice and no black ink on the paper.  I cleaned the rollers but still the black solid lines.......  HELP.  Thank you
Moderator
[ Edited ]
Hi, 1985slh!
To have a better understanding of your issue, please let everyone know the model of the printer you have.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help via Email at http://Canon.us/SupportCF
You can also use the following link to browse our library of user manuals by clicking HERE.
Thanks!
Occasional Contributor
I can't see your scanner, but scanners have to be perfectly clean or else you will see some line if there's anything resting on the glass where the scanner moves.
New Contributor
Sometimes cleaner will not get everything.  I had to use a plastice credit card and lightly scape the surface to get it completely clean
Re: Black vertical line on copies
If the line is occuring when printing to the device, it is most likely the Drum or Imaging unit. You will need to buy a new one to remedy the line.
New Contributor
I have an Canon Imagerunner 3035. It suddenly has been showing thick vertical lines. It also notce that it has a greater tendency to do paper jams and seem to be running hot.
I disconneted the machine however, I am concerned that reconnecting is not going to be enough. What do you recommend?
Neil Binder
mr 19th !
Thank you so much! Due to your precise description, I was able to clean the smudge off the little glass on my MX 922 and eliminate my problem!
Maje
New Contributor
I have this same problem but only on the feeder loads, manual placement yields exact copies. Why?
powered by Lithium
