01-11-2020 02:16 PM
Am new to this forum, so I hope I am doing this right!
My new Selphy CP1300 prints the pictures too big. It ends up cutting of heads and other important things.
Any suggestions?
Thanks!
01-13-2020 03:35 PM
Hi awasbell4,
Are you printing from a mobile device or a computer?
If it is a mobile device, is it iOS or Android?
Are you using the Canon Print Inkjet/SELPHY app to print your photos?
If you are using a computer, what version of Windows (or OSX) is installed on your computer?
If using a computer, what application are you using to print your photos?
01-13-2020 06:58 PM
I was printing from my android.
First I was using the Canon app. Then I used my phone and just added the printer.
I did discover that if I go in and edit the picture and turn it sideways, it will not cut anything off. Of course, the picture is no longer 4 x 6.
What do you think?
A
01-15-2020 12:19 PM - edited 01-15-2020 12:19 PM
Hello awasbell4.
From your description, the problem seems to be the formatting of the image and the use of Borderless printing.
When using the Borderless option, the outer edge of the image, referred to as the "bleed," is extended to cover the edges of the paper. If a target's head is in the bleed, it is likely to be outside of the realistically printable area.
Make sure the image you're printing has a decent margin outside of what you wish to print to allow for the bleed, use bordered printing, and, if printing from a computer or smartphone, look for a "fit to page" or "reduce size" option to fit the whole image in the printable area.
If you need immediate assistance with this issue, please contact us using the numbers and information at http://Canon.us/ContactLI
03-03-2020 02:33 PM
I am having the same problem. I am printing from an iphone via the Canon App. I do not see a "fit to page" prompt. I have tried calling tech support but can't get anyone on the phone. I am on the verge of just returning the printer.
03-05-2020 02:53 PM
rkrbrannan,
If borderless printing is enabled, the image will be extended beyond the normal size of the paper in order to guarantee an edge to edge printout. If you want to retain the entire photo without any extension, please use the bordered option before printing from the Canon PRINT app.
01-16-2020 03:53 PM
07-19-2020 12:34 AM
07-19-2020 12:35 AM
07-19-2020 08:25 AM
