Reply
New Contributor
solar eclipse
going to be directly in the path of the total solar eclipse in Aug.  shooting with a 500f4 lens.  will Baader film taped to the hood, be strong enough to shoot partial> full eclipse without harming the lens?
Respected Contributor
Re: solar eclipse
[ Edited ]
I don't know what Baader film is, but I had good luck with these:
http://thousandoaksoptical.com/solar.html
If you are lucky, you might not need a filter:
New Contributor
Re: solar eclipse
did you tape this on?
Re: solar eclipse
[ Edited ]
The thousand oaks filter comes with a metal ring that I slipped over the lens hood of my 150-600 and secured with tape.
Esteemed Contributor
Re: solar eclipse
[ Edited ]
Do a web search for "solar photography filters".  They sell threaded filters that screw on your lenses in many standard sizes.  An 5.0 ND filter is what I have found.
Honored Contributor
Re: solar eclipse
For $3 or $4 bucks you can buy welding glass.  You need to shoot RAW because the welding glass has a green tint which must be corrected in post.  Easy to do.
You will probably need to tract the Sun, too.
A lot of Canon stuff. Along with, a lot of other stuff.
Re: solar eclipse
If you need to track, you have too much filter. Both my filtered and unfiltered exposures were reasonable. You do need a tripod, though.
Re: solar eclipse
My favorite NYC online superstore has a small selection of "solar eclipse" [5.0 ND] filters, including "clear" filters.
Re: solar eclipse
And you probably wouldn't want to track. You're not photographing some distant galaxy. Eclipses happen fast, and a tracked image would be blurry and confusing. Maybe OK as a work of art, but not as an accurate record of a once in a lifetime astronomical event.
I hope you'll be luckier than I was. I was literally at the best possible location to view the total solar eclipse of 1964. The American Astronomical Society was there too - invited by my uncle, who was head of the Astronomy Department at the University of Maine. Clouds obliterated the entire event.
Bob
Boston, Massachusetts USA
Frequent Contributor
Re: solar eclipse
Harming the lens? I'd be a little more concerned about going blind. If you are going to bet your eyesight on a piece of tape, then I wish you the best. If it were me, I'd be using a proper solar filter.
powered by Lithium
