Reply
New Contributor
canon 5D lense
HI
My Canon 60D camer was drowned so I bought recently a 5D MARK II instead. BUt i just found out that some of my 60D lenses cannotbe mounted on the 5D
Is there any adaptor that I could use in order to be able to use those lenses on the 5D or is it a lost case ?
Thanks in advance
Esteemed Contributor
Re: canon 5D lense
mpanol wrote:
HI
Thanks in advance
It's a lost cause. EF-S lenses cannot be mounted on a full-frame camera.
Bob
Boston, Massachusetts USA
Honored Contributor
Re: canon 5D lense
mpanol wrote:
HI
Thanks in advance
Bob is correct.  There are not any such adapters out there to be had.
Any Canon EF-S lenses will not only fail to mount properly to full frame camera body, even if you could find an adapter, the image circle projected by an EF-S lens is not large enough to completely cover a full frame image sensor.  Any adapter would only give you a circular image, which wouldn't be a fisheye image, either.  Finally, EF-S lenses have internal components that may collide with the mirror inside of a full frame camera body, so you probably wouldn't want an adapter even if you could find one.
powered by Lithium
