Which lens should i buy?
Eschacher
Hello,
I have a Canon EOD 600D and i'm looking for the best camera there is for portrait and food photography. Ideally with F/2.8 or lower. Can anybody reccomend something suitable that will fit my camera body?
Thank you!
11 REPLIES 11
jrhoffman75
Depending on your budget one of the Canon 85mm lenses would be a good choice for portraiture, particularly if you intend to upgrade to a full rame body at some point. A little long FL on a Rebel, but just step back a little.
If you don't plan on upgrading a 50mm lens on a Rebel will give you a 80mm field of view, which close to the traditional portrait lens of 85mm on a 35mm camera.
Sigma also has highly rated 50mm and 85mm Art series lenses.
ebiggs1
Your answer really requires more than one lens to totally satisfy it.
However if you are committed to one lens, the Canon EF-S 17-55mm f/2.8 IS USM Lens is what you want.
kvbarkley
VIP
VIP
You might also want to look at the EF-S 60mm Macro.
Do you want a really sharp lens, or a softer look?
I'd ideally like to stay away from a fized zoom lens. The sharper the better in this situation. Thanks for your reply!
If you Google "best lens for food photography' you get many hits. 50mm lens seems to be a big favorite.
TCampbell
Use the term "best" with caution... usually the "best" isn't cheap.
For portraiture, where a blurred background is often preferred to help separate a tack-sharp subject from the background, a "full frame" sensor camera is able to generate more blur.  Your camera has an APS-C size sensor so things change a bit.
For food photography I typically always use a macro lens.  On your camera I'd use the EF-S 60mm f/2.8 Macro USM.  I use the EF 100mm f/2.8L IS USM but I"m on a full-frame camera.  One reason that I use a Macro is because when I'm shooting food I'll often be including detail shots and for that I need the close-focusing distance.  Also Macro lenses tend to have optics designed to offer very good detail resolving capability (the "MTF" curve that shows off the accutance of the lens is usually much higher than a lens that you'd use for portraits.  In fact... for portraits you sometimes deliberately want to "smooth" the subject's skin, etc... too much detail often doesn't look as attractive.)
For portraiture it really depends on if you're shooting indoors vs. outdoors ("studio" vs. "environmental" portraiture).  A longer lens tends to work really well, but you have to be much farther from your subject and indoors you typically don't have the space.
When shooting (especially indoors) there's the notion of the portrait size... is it a "head & shoulders" shot, a "half-shot" (shooting the subject from the waist up), or a "three-quarters" shot ... or a "full shot" (entire body from head to toe).  The 85mm is a nice focal length for portaits outdoors, but indoors an 85mm lens will limit you to "half shots" (usually just a single subject in the frame and you can capture them from waist-up) because getting multiple subjects or full-length shots will require a much larger room so you can move back farther.  Using an 85mm lens on an APS-C crop-frame body is roughly the same as using a 135mm on a full-frame body in terms of the true angle of view.
A 50mm will buy you more angle of view but you wont be able to produce quite as much blur.  The new 50mm f/1.8 'STM' (emphasis on it needing to be the STM) moved up to 7 aperture blades from the previous f/1.8 non-STM which only had 5 blades (and they weren't well-rounded).  The quality of blur is noticeable smoother on the STM version of the lens.
BTW, when I shoot food, I seldom use a focal ratio lower than f/4... I typically at least want the main dish to be focused even if I want everything else blurred and when I do want everything else blurred I typically want the items to be blurred... but at least recognizable to the point that they offer the suggestion of what they are (e.g. I want the viewer to notice there's a "wine bottle" in the background even if they can't actually read the label.).
Tim Campbell
5D III, 5D IV, 60Da
Thank you for your reply.! Gives me something to think about. Price doesn't really bother me at this point. Can you reccomend one Canon lens that would be perfect for both food and indoor portraits? Also, is there a full frame body that is affordable and would fit this lens?
Thanks!
"Can you reccomend one Canon lens that would be perfect for both food and indoor portraits?"
Yes, already did !
"the Canon EF-S 17-55mm f/2.8 IS USM Lens is what you want."
"... is there a full frame body that is affordable and would fit this lens?"
No.
If you want a lens similar to the Canon EF-S 17-55mm f/2.8 IS USM Lens in a FF version, you want this lens, EF 24-70mm f/2.8L II USM Lens.  And, you want the EOS 6D to go with it.
Like I indicated earlier, you really have a multi lens situation.  Portraits and food are different subjects ans require different equipment to get the best results.  But this is the best thing about a DSLR.  You can match the right combo for the conditions at hand.
One note, your Rebel T3i and the Canon EF-S 17-55mm f/2.8 IS USM Lens will do a great job for both.  Don't under estimate that combo.  Although you said money wasn't your biggest concern, the FF option doesn't come cheap. Comparatively.
Enter for a chance to win!
April 20th-28th
