05-16-2014 05:18 PM
what size filter will fit canon EFS 18-55 mm lens?
10-28-2016 04:50 PM
@Waddizzle wrote:
@nirjan169 wrote:
I have canon Rebel t5 and I am using 55-250 zoom lens. So, is the lens compatible?Yes. There have been a few variations of the EF-S 55-250mm lens, as well as the EF-S 18-55mm camera kit lenses, but I think they were all 58mm. You should note the complete model number of the lenses, and consult your vendor to be certain.
As Skirball pointed out earlier in this thread, every Canon lens (and probably every lens) has its filter diameter etched on it. All you really have to do is look.
10-28-2016 03:21 PM
10-28-2016 03:25 PM
10-28-2016 03:32 PM
Actually a better place to buy it is B&H or Adorama. Either will answer any and all questions you might have. Also make sure you get the one that is named Canon EF-S 18-55mm f/3.5-5.6 IS STM Lens. A even better choice, although more expensive, is the Canon EF-S 17-55mm f/2.8 IS USM Lens.
Besides buying a protecto filter, what filter are you considering. Filters are virtually obsolete in the digital age.
10-29-2016 08:19 AM
10-29-2016 09:36 AM
@nirjan169 wrote:
The complete model number is CANON ZOOM LENS EF-S 55-250 mm f/4 - 5.6 IS II.
That's a pretty good entry level lens. You should see "58mm" stamped on the front of the lens. Buy that size.
A protection filter would help protect the front lens element. Filters that fit your 55-250mm will your 18-55mm camera kit lens, too. As the 55-250mm lens isn't very expensive, I might look for a 3-4 filter kit. You filters would be interchangeable.
I like having a Clear protective filter, a UV filter, a CPL filter, and a ND filter, in that order. I like to shoot outdoors, landscapes and cityscapes. I grew up near the water, and love to photograph it. The ND filters are useful for long exposures.
I use Clear filters on all of my lenses because I am somewhat clumsy, especially when it comes to replacing a lens cap back onto the front of the lens. Clear filters are not usually found in a filter kit.
10-29-2016 10:52 AM
@Waddizzle wrote:
@nirjan169 wrote:
The complete model number is CANON ZOOM LENS EF-S 55-250 mm f/4 - 5.6 IS II.That's a pretty good entry level lens. You should see "58mm" stamped on the front of the lens. Buy that size.
How does a "clear" filter differ from a UV filter? Does it actually admit UV light? I ask because most glass is pretty good at blocking UV. The reason photochromic sunglasses don't work well inside a closed automobile is that the windshield blocks most of the UV. In hospitals and old folks' homes with sunrooms that are supposed to allow UV in, they have to use special window glass. In the old days I guess a UV filter kept UV light from fogging the film, but in a digital camera there's no film to fog. So if a filter is used only to protect the lens from thumbprints and scratches, what difference does it make whether it blocks or admits UV?
10-29-2016 11:45 AM
"How does a "clear" filter differ from a UV filter? Does it actually admit UV light? I ask because most glass is pretty good at blocking UV. The reason photochromic sunglasses don't work well inside a closed automobile is that the windshield blocks most of the UV.
In hospitals and old folks' homes with sunrooms that are supposed to allow UV in, they have to use special window glass. In the old days I guess a UV filter kept UV light from fogging the film, but in a digital camera there's no film to fog. So if a filter is used only to protect the lens from thumbprints and scratches, what difference does it make whether it blocks or admits UV? "
Good question. All that I can go on now are manufacturer's claims. I know that my exposures seem to be more accurate when I use the UV filter when shooting landscapes. Is there a difference between Clear and UV? Supposedly, there is.
10-29-2016 05:36 PM
Guys it isn't totally true that digital sensors are not effected by UV. They aren't at sea level but high up in the mountains they can be.
You don't have to use a UV or skylight filter if all you want is to protect your lens. A clear filter is all you need.
One thing I might add is multi-coated filters help improve contrast and reduce reflections. The quality of the filter should be the same as the quality of your lens.
Don't get me wrong. Polarizers, ND filters all have a place. It is just there place has been reduced greatly with the advent of digital and the advanced ability of PS. It is a lot quicker to slap on a filter then it is to spend quality time with your post editor. But it can be done.
