Reply
Frequent Contributor
Re: My circular polarizing filter doesn't seem to have a very wide change spectrum?
Remarkable results with your HDR....I am interested in HDR but have no real understanding of it.  I get the impression you dont need a lot of lenses?  ? what? I saw friends on a recent trip to the mountains raving about the little bit of weight they took with their cameras...I'm not sure I understand HDR at all right now?
VIP
It is easy.  Basic set up. Take three or more exposures.  One under, one correct and one over exposed.  You need a post editor.  I like and use Photomatrix Pro.  It automaticly stacks the exposures and applies the correct settings.  Plus it has other features for further adjustments.
There is a free trial version.  BTW, Photoshop can do it, too.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
VIP
Here is a "Old Red Barn" they are restoring close to me.
Give it a try, sometime.  Smiley Happy
Respected Contributor
[ Edited ]
You need a tripod, not a lens.  Well, obviously a lens, but a tripod is the standout requirement for HDR.  Basically all you're doing is taking photos as multiple exposures (very dark, dark, normal, light, very light) and combining them into one image with a large (or "High") dynamic range (the 'distance' between the darkest and lightest points in an image); hence the name HDR.  You can shoot it without a tripod, most software can try to align the frames, but it's much better to just use a tripod if available.
As mentioned above, Photomatix is the name brand in HDR, but that's changing and the technique evolves.   It's far superior to control in Photoshop, however.   There's a plug in for Lightroom called Enfuse (free) that is very powerful, but not as user friendly.  And the soon to be released Lightroom 6 will have HDR built in; we're all eager to see what that looks like.
The examples that eBiggs posts really show tone mapping more than HDR.  All HDR (and non-HDR) images have to be tone mapped to display on a LED screen, but if you search for "tone mapped" you'll see that there is a look associated with the term.
On the flip side, HDR images can be tone mapped to look normal, mearly trying to squeeze a large dynamic range into one picture. A very common use is in Real Estate/Architectural photography when dealing with lots of windows.  The difference in light levels between the inside lights and outside can often be far too large for a camera (even though your eyes can adjust ok).  So you're left with either completely white windows, or dark interior.  The goal isn't to make something that looks 'tone mapped', but to have it look normal.  Like this:
Even with lighting I couldn't completely balance out the sun, so I simply stack a few images to fill in the low spots.  It doesn't look like anything special, but it's not supposed to.  You can see the outside has a slight bluish tint to it.  Poor tone mapping on my part.
Another example, where the left and back walls were windows, creating a bright gradient out of the lower left, leaving the back completely dark.
Again, you're not suppose to look at it and think HDR, it's suppose to look like an ordinary photo.  Just some examples of another side of HDR...
VIP
iris,
A tripod is certainly the best way to do HDR but not a requirement by any means.  Both of the shots I posted are hand held.  You do need at least three exposures and five is better.
HDR has great ability for adjustment.  The two old barns have a certain amount of things dome to make them look like they do.
I printed them on pearl metalic paper for that certain look, too.  They are stunning in real life and they sell very well.
It is possibile to do HDR that has a normal look or at least as normal as HDR can be.  Since the range is vastly extended.
Photomatrix Pro, my choice software, is a plug-in for Lightroom.  So you can start in LR do your stuff. Click the plug-in go to Phtomatirx and let it do its stuff and bamm you are back in LR.
This isn't new. The term HDR maybe new but PS could always do this.  And I used to do it in the darkroom with film.  We just didn't call it HDR.
There is even video HDR but I am a stills guy.
Occasional Contributor
IMHO the easiest way to check a "polarizer" is to hold it in front of an LCD (computer or TV) screen and rotate it while looking through it *(with an image displayed on the screen). The view through the "polarizer" should "go black" at some point in the rotation:
                     1.) IF screen is LCD
                     2.) AND polaroid filter is functional
                     3.) THEN screen as viewed through rotated filter will darken
                     4.) ELSE screen is not LCD
                     5.) OR polaroid filter is not working
Note: There are different types of screens, LCD and NOT LCD. (LCD=Liquid Crystal Display)
          Typically Sony TV screens are LCD, while Panasonics are not (different technology)
Give it a try...
WDM
Esteemed Contributor
It helps to understand what a polarizing filter actually does.
Light travels as a wave.  The wave has an orientation.  As light leaves its source (e.g. the Sun for example) the orientation of the wavelengths is random.   But when light boucnes off any surface, it will take on an orientation based on the angle of surface that reflected it.  The shinier or more reflective the surface... the stronger the effect.
If light is originating from a direction which is EITHER roughly directly ahead of you OR directly behind you, then the orientation of the waves will still be random and the polarizer will seem to have little to no effect.
If the light is originating from a direction which is orthogonal to you (come from the sides or above) then the light will be strongly polarized to a specific orientation as it reflects.
The polarizing filter has parallel lines which you can think of as a series of "slits".  If the orientation of the wave matches the direction of the slit then the light passes through.  If the orientation of the wave is orthognal to the orientation of the slit then the wave of light is absorbed.
When you use a polarizer on a cloudy day, the clouds will diffuse the light (light a giant "soft box") and the light will seemingly originate from all around you.  The polarity of the light waves will be random because the surfaces that reflected those waves were also random.  It will seem to have little effect.
On a sunny day, the polarizer will have a very strong effect.  Foliage looks greener because part of what you see without a polarizer is the natural color of the leaves, but the leaves also have a reflective coating -- so part of what you see is light reflecting off a shiny surface and not the true color of the leave.  When you add the polarizer (and tune it) then you block the reflections but allow the natural color of the leaf to come thorugh.  It isn't so much that the polarizer saturates colors... it's that it blocks reflections so that you can see what was hiding behind the mirror surface.  If there was no mirror-like reflection then you wont see any color saturation as you tune the filter (you are already seeing the natural color of the objects.)
The sky looks bluer because of tiny impurities in the air (which can even be humidity) and these are reflecting light.  The intensity of the polarizer will changed base on the "transparency" of the air and the nature of the impurities in the air.
Lastly... when you use a polarizer on a lens at a very wide focal length, the amount of light blocked will change based on the angle of the light.  This creates a dark-ish band in the area where the polarizer is blocking most of the reflections and will weaken as you get farther from that sweet-spot.  The result is an image that appears to have a dark-band going through it.  Polarizers look best when used on normal to long focal lengths.
Tim Campbell
5D III, 5D IV, 60Da
For what it's worth I have several Hoya CP's basically one for each lens, in my experience even when I am even 90 degrees to the light plain I have experienced less than I thought for effect, what I discovered is, my eyes are the problem lol, between that and the reflection on the LCD it only appeared that what I saw was less effect, when I looked through the viewfinder I then saw what I was looking for, just thought I would mention it.
The only culprit I can think of is light reflecting off of your glasses. If it doesn't make it through to your eyes, it won't matter what its polarization is.
Bob
Boston, Massachusetts USA
It occurred to me the other day that if the 90 degree angle rule to the sun is always applied, one can only get good blue sky effect faceing North or South....youll never be 90 degrees to the sun facing East or West?
I find some of the best use for polarizing filter for seeing though windows or removing glare from surface water.....
powered by Lithium
