11-17-2017 03:58 PM
I have a Canon t3 and when I came back from outside the lens turned extremly foggy. I checked the internal lens, and the external and both seemed not foggy, but when I turned it on again it was still foggy. Even right now it is still foggy, help???
11-17-2017 04:31 PM - edited 11-17-2017 04:34 PM
It was cold outside so the glass did in fact fog up when you came in.
You can minimize that by taking a couple of large airtight bags out with you. Before you come back in put camera in one, lens in the other and push the air out before sealing. This will minimize the amount of moist air available to make condensation on the cold glass. Leave in bags an hour or more in a warm place until they warm up.
If you do nothing the camera will just warm up and the condensation will evaporate, but if you do that frequently and water spends a lot of time in the lens you can get fungus growing on the internal glass elements and you can't get rid of that.
11-18-2017 10:06 PM
Worked, I did some rice instead thank you!
11-18-2017 08:28 AM
One of two, 1st the lens is a not a Canon lens and 2nd if it is, it has lost its seal. If it indeed has lost its seal you may never get the moisture out. Call Canon service.
If it is not a Canon lens, you get what you get! Who knows?
11-18-2017 10:16 PM
ebiggs1 wrote:One of two, 1st the lens is a not a Canon lens and 2nd if it is, it has lost its seal. If it indeed has lost its seal you may never get the moisture out. Call Canon service.
"Lost its seal"? Since when is the kit lens on a T3 sealed against air leakage?
11-19-2017 09:37 AM
Robert do you not have better things to do except read a post with a magnifying glass? Sealed as in terms of keeping moisture out. Not as scuba gear, need I say that to clarify, too? This lens obviously got water inside.
It probably needs disassembly and reassembly. That needs to be done by Canon.
"Air", who mentioned air?
11-19-2017 02:33 PM
ebiggs1 wrote:Robert do you not have better things to do except read a post with a magnifying glass? Sealed as in terms of keeping moisture out. Not as scuba gear, need I say that to clarify, too? This lens obviously got water inside.
Air (in particular, humid air) is what brings the water in. Fogging occurs when the lens gets cold and the water condenses out on the glass elements. You knew that. Haven't I seen you write about that very process?
11-20-2017 10:15 AM
"You knew that."
Gee, I believe you are right.
"Haven't I seen you write about that very process?"
Quite possible.
