Reply
New Contributor
Accepted Solution
Lens filter for EF 50mm 1:1.4 lens?
[ Edited ]
Every time I shoot (video mode) with a 58mm lens filter of any type on my EF 50mm 1:1.4 lens, there is a noticable reflection in view. But I can't shoot without a filter (I always use polarized) because I can't get them to look that good in an editing program. My whites are too bright in outdoor shooting, and the only way I can see the sky is if I make the rest of the scene too dark. A polarizing filter seems to be the only thing that fixes that.
Are there any other filters or accessories I can use instead of the 58mm filters? I know it'd look better if the filter was closer to the lens since the lens is sort of concave... would smaller filters fit?
Or better yet, is there a way to balance my lighting & color in outdoor settings that doesn't require a filter?
I've already tried changing the ISO, exposure, etc. and the white balance. Still no luck.
(My camera is a Canon EOS Rebel T2i with an EF 50mm 1:1.4 lens, shooting in video mode.)
Esteemed Contributor
Re: Lens filter for EF 50mm 1:1.4 lens?
Are you using a lens hood?
Bob
Boston, Massachusetts USA
Respected Contributor
[ Edited ]
AlyssaHuberFilm wrote:
Every time I shoot with a 50mm lens filter of any type on my EF 50mm 1:1.4 lens, there is a noticable reflection in view. But I can't shoot without a filter (I always use polarized) without my shots looking overexposed or washed out.
Is there any other filters or accessories I can use instead of the 50mm filters? I know it'd look better if the filter was closer to the lens since the lens is sort of concave... would smaller filters fit?
Your EF 50mm f/1.4 USM uses a 58mm filter, not a 50mm filter. Filters should screw on to the front of the lens.
Your statement about requiring a polarizing filter so your shots are not overexposed or washed out indicates a user problem, as that is not normal.
Try taking a photo without any filter in 'green square mode', that takes out most of the 'user settings'. Are the photos in 'green square mode' overexposed and washed out? If not, you need to figure out what user setting you have that is messed up.
VIP
What camera?  Reset it to defaults.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
New Contributor
Nope, I don't own one. My biggest issue is that my whites are too bright compared to the darks, and I can't seem to fix that without a filter.
New Contributor
My bad, I actually have a 58mm lens filter. It fits perfectly but there is still the reflection issue. I edited my post because I didn't explain very well what my shooting issue is. It's mainly that my highlights are too bright and I can't see the sky without darkening everything else too much.
I should have also mentioned that I'm in video shooting mode. I only use it for video so I'm not sure what you mean by "green square mode."
Photographing outdoors in the noonday sun should be the easiest thing to do, assuming you are taking "normal" photographs of people or scenery.
We need more info of exactly what you are doing. Can you post screen shots.
1D X, Rebel T5i, Many lenses, Pixma PRO-100, MX472
[ Edited ]
What are your exact settings when shooting video?
First you need a lenshood.
Second you need to be sure you are using a quality filter. A quality 58mm Circular Polarizing filter costs between $45 and $60. If you paid less than $45 for your filter it most likely lacks the coatings need to prevent reflections. Look at a B+W filter with Multi Resistant Coating (MCR) or better yet B+W's Multi-Resistant Nano Coating.
Highlight Tone Priority (HTP) and Auto Lighting Optimizer (ALO) are two camera settings that will help bring up the shadows in high contrast scenes.
This was the first thought that came to mind... the filter needs quality anti-reflective coatings.  You might want to look at a B+W brand circular polarizing filter with their "MRC" coatings.  (It wont be cheap).
Tim Campbell
5D III, 5D IV, 60Da
New Contributor
Thank you, I have purchased an MRC polarizing filter as you recommended, and there is no more reflection!
powered by Lithium
