Reply
Super Contributor
First third-party lens
I am thinking about purchasing the Sigma 18-200mm F3.5-6.3 DC Macro HSM lens.This would be my first third-party lens purchase. It would obviously be used as a walking-around lens. If I buy it, I'll likely buy directly from Sigma.
A couple of questions. Does anyone have this lens? If so, what has been your experience with it? I am a little concerned about the sizable range of 18-200mm, in terms of photo quality, especially at the tele end.. Yet the examples I've seen online seem very good to me.
I'd be interested in your thoughts.
Honored Contributor
Re: First third-party lens
I think the ratio of the longest to the shortest focal lengths is to great for IQ not to have suffered in the design of the lens.  Judging from that range, I'd say that you're trying to kill two birds with one stone.  I use three lenses to cover a similar range.
EF 16-35mm f/2.8L II USM
EF 24-105mm f/4L IS USM
EF 70-200mm f/2.8L IS II USM
I am not suggesting that you go out and buy those particular lenses.  I am saying that if you want to up your game, then a lens with a focal range of f/3.5-6.3, and a zoom ratio of 10:1, is not going to do it.  Go for fast lenses, with a zoom ratio of 4:1, or less.
I forget.  What camera body are you using?
Super Contributor
[ Edited ]
I am using the T6. And I hear you about the 10:1 ratio. I think there might be too many compromises made in that lens. I think something closer to 24-105 might be where I need to move next.
Edit: I should note that the T6 was purchased with the intent of helping me learn about DSLR photography at a low entry-level price. In that regard, it is serving its purpose quite well. But I believe that I will soon be ready to move on to something bigger and better. Rumor has it that the 6D Mark 2 is near release. I should probably sit tight for a little while on the lenses. I may move up to full frame yet! Smiley Happy
https://petapixel.com/2017/06/15/canon-6d-mark-ii-new-26mp-sensor-june-29-unveiling-report/
Honored Contributor
[ Edited ]
Before you start buying high quality lenses, i suggest that you make a decision as to whether you want to buy EF mount lenses, or EF-S mount lenses.  I had bought a T5, and outgrew it within a few months.
I knew I wanted a new camera body, but didn't know enough about the different models to choose one.  But, I did know enough about the lenses to know that EF mount worked on any camera, and EF-S did not.  I chose to only buy EF lenses because they worked on all camera bodies.
After buying a couple of EF mount lenses, I noticed that they seemed to be better built than EF-S lenses.  Although, the EF-S 10-22mm f/3.5-4.5 is a definite exception to that observation.
I assembled my lens bag one lens at a time.  I have not seen a new EF mount lens from Canon, which was not an "L" series lens, in a couple of years.  Most EF lenses are quite older designs, most of which are outperformed by EF-S "STM" lenses.  I figured that if I wanted EF mount lenses, then they would have to be "L" lenses.
I am certain that the T6 can produce pretty good images.  I know my T5 can produce high quality images when used with high quality lenses.
Why do you think you need a new lens?  What need is the Sigma 18-200 fulfilling?  What do you gain with the 18-200mm?
[EDIT]. I'm not asking these questions because I want to know the answers, as much as you should be asking yourself these question.
Esteemed Contributor
It's more difficult to achieve good optics when the glass elements have a physically larger diameter.  In other words it's possible to create high quality optics in a smaller size for less money.  But the catch is that the image circle being projected isn't big enough to cover the size of a full frame sensor.
So there's certainly a cost advantage of the EF-S lenses.  But beyond this, there are some EF-S lenses that are designed with affordability in mind.  However, there are are some lenses that are fairly impressive.
Originally the great EF-S lenses were the 17-55mm f/2.8, the 10-22mm and the 60mm macro.
But recently, Canon redesigned a few lenses and is now offering them with the "STM" focus motors.  All the EF-S lenses with "STM" motors also have redesigned optics and they're all significantly improved over their predecessors.
The zoom lenses, however, have different focal length ranges based on the sensor sizes.  For example, the EF-S 10-22mm on a Canon APS-C sensor body is actually the equivalent of the EF 16-35mm when used on a full-frame sensor body ... that is to say both lenses actually provide the same "angle of view".
When the focal length of a lens exactly matches the diagonal measure of the imaging sensor then that lens would offer a 1.0x magnification.  For an APS-C camera that's about 27mm.  For a full-frame camera that's about 43mm.  Nobody actually makes a 27mm or 43mm lens.  So for an APS-C camera, the 28mm lens is about as close as it gets and for a full-frame camera the 50mm lens is considered the "normal" focal length (also the 40mm pancake lens is pretty close.)
If you were to use the EF 24-105mm (a lens designed for full-frame sensor cameras but will work on any Canon EOS camera) then you'll find the lens has almost no wide-angle (24mm is too close to 27mm) so it's pretty much a "normal" focal length through telephoto.  For the EF-S lenses the low end is commonly around 18mm on most general purpose zooms (although you can get wider lenses.)
Most general-purpose lenses (aka "standard zoom") offer a bit in the wide-angle direction as well as a bit in the narrow angle direction.
Tim Campbell
5D III, 5D IV, 60Da
One additional point worth mentioning is that an EF lens of a given focal length may actually perform better on an APS-C camera than on a full-frame camera. That's because you're only using the center of the lens's image circle, and the sharpness of any lens tends to fall off nearer the edge. So if, for example, you're willing to overlook the fact that it doesn't have much of a wide end, the 24-105 can be a very nice walking-around lens on your T6 while you're waiting to go FF. I bought that lens with my second 7D because I planned to go FF eventually. And while I didn't use it a lot before I got my 5D3, it produced excellent results when I did use it.
Bob
Boston, Massachusetts USA
Honored Contributor
I followed a similar route.  I had bought the EF 24-105 f/4L before I had a full frame.  I figured that I still had my T5 kit lens available for "wide angle" shots.  After using th 24-105 one time, I realized how bad the kit lens really was.  I wanted a fast, wide angle lens, which led my to buying a Rokinon 14mm T3.1 cinema lens.
Thanks to the short hyperfocal distance of the 14mm lens, I can dial in the focus at infinity, and everything beyond a few feet is in razor sharp focus.  I do not need to adjust the focus ring.  It's perfect for outdoor shots.  It is a relatively inexpensive lens, and I waited to buy it when it was discounted.
Now, the Sigma you were looking at seems to have a number happy users.  It can probably fulfill the snapshot roll ver well.  Just be aware that because it is a third party lens, your camera cannot compensate for it, and neither can Canon's DPP software.  If you are using Lightroom, then compensating third party lenses is not an issue.
VIP
[ Edited ]
John,
I have owned many, many lenses over the decades.  The Sigma 18-200mm F3.5-6.3 DC Macro HSM lens has not been one of them that I can remember, anyway, but I strongly urge you to reconsider.  I suppose it is what you expect and the goal you wish to achieve.  I have no doubt it will take pictures.  The question is, how good?  But how good is good?  That is for you not me to decide.  It will certainly be better than a cell phone.
Let's consider something, third party lenses can be not just good but very good.  Some of the time they are a better buy, too. Some are half the cost of a Canon lens of the same focal length.  For instance, the Sigma 24-70mm f/2.8 IF EX DG HSM Lens is a real nice lens.  Along with its big brother the Sigma 70-200mm f/2.8 EX DG APO OS HSM comprise a truly nice bag.
Not to the level of the Canon duo in this focal length but both of the Siggy's will cost what just one of the Canons!
To conclude, the best advice is to buy real deal Canon if you can.  If there is a good reason to look elsewhere, than give the third world a look.  IMHO, I would go for the Canon EF-S 18-200mm f/3.5-5.6 IS Lens if I just had to have that unreasonable focal length.  Check it out.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
Super Contributor
Thanks for all the tips, guys. I appreciate it, and inasmuch as I sincerely value your wealth of knowledge and expertise, I have decided to shelve the purchase of the Sigma 18-200mm lens. I agree, it was not a well-thought-out decision and I am glad I sought out your thoughts before making the actual purchase.
I think that I am going to do a couple of things. First, I am going to wait for the coming release of the 6D Mark II and see what kind of reviews it gets. But whether I go with the Mark II or some other entry-level full frame camera, I believe that full frame is the direction I would like to head in. Thus, I will move away from EF-S lenses and slowly build up my repertoire of EF glass, which I can still use on my crop sensor camera. I agree, buying bargain basement lenses will not be satisfying to me, no matter the low price.
Thank you all again for the sound advice. I believe it saved me from making a poor purchasing decision.
And Happy Father's Day!
Honored Contributor
ebiggs1 wrote:
John,
Canon has the lens Ernie recommends on sale in the refurbished store.  I have purchased several lenses there.
https://shop.usa.canon.com/shop/en/catalog/ef-s-18-200mm-f-35-56-is-refurbished-17976-1
They are asking for less money than your Sigma.  Get a Canon hood for it from B&H, if Canon is out of stock.
powered by Lithium
