Reply
New Contributor
Re: EF-S v EF Lens - Crop Factor (Image Conversion Factor)
Thanks John. Not the answer that I was hoping for, but at least I understand it now and I will shop for a 10mm lens for my interior shots.
Honored Contributor
There are two wide angle Canon zoom lenses made for EF-S mounts, a 10-18mm STM, and a 10-22mm USM.
New Contributor
Perfect. Thank you!
VIP
Crop factor is a big joke.  It is a meaningless term invented to slap on certain sensors because they had to come up with something.It is nothing short of confusing to most people.  Even long time photographers think the crop sensor camera actually crops their image. People on all the photography forums will say so. It crops nothing!  All camera no matter what size sensor they have are FF in the sense that you get what you see in the viewfinder, nominally.
If you notice they don't call P&S cameras "really cropped sensor".  And they don't call medium format cameras "expando sensors".
Again if you have a 50mm lens and could put it on a P&S it would still be a 50mm lens.  Even putting it on the medium format or large format body, it is still a 50mm lens.
A better way to think about it is "angle-of-view".  There are charts that quickly tell you exactly what it is.  On your 'crop sensor' body you need a 18mm to 16mm for a WA angle of view.  A 14mm to 10mm is considered an ultra wide angle.
A lot less stuff for 2018 but still a lot of Canon stuff. Along with, a lot of other stuff.
Esteemed Contributor
I agree with Ernie that angle of view is a more comprehensible comparison vehicle than crop factor. But I think it's even easier to simply learn how a given lens behaves on each type of camera. I've found that the only times I've had to actually consider a len's "full-frame equivalence" is when I'm planning a shoot with both a FF and an APS-C camera, to make sure I don't have a coverage gap.
Bob
Boston, Massachusetts USA
Back in the day, when 35mm film was dominant in the market, for better or worse, the focal lenghts of the lenses for the 35mm system became the standard nomenclature for a particular angle of view.
Along came APS (Which I liked by the way, it was a good bridge to digital, with a first stab at film based "EXIF", but I digress). Since all the major manufacturers had interchangeable lens APS systems, there had to be a way to explain that the angle-of-view of a 50mm lens for APS was different than for 35mm and crop factor was born.
Since the first digital bodies had APS sized sensors, it was natural to keep 35mm focal lengths as the "standard" and use a crop factor to get a handle on the angle of view.
I think it is a handy way to understand the angle of view for a particular focal length. To answer the question above, it only matters for interchangeable lenses.
New Contributor
Thanks for the walk through memory lane. I think I got it now. 35 mm (24mm x 34mm) was dubbed a standard and hence dubbed "full frame". Anything other than a "full frame" size is just a different frame size and hence has a different angle of view. A way to express the angle of view is to compare it to to the standardized "full frame" via a ratio or multiple, such as 1.5, 1.6, 1.35, etc.
Thanks to everyone that responded. Very educational,
powered by Lithium
